I would start with the important stuff, rock rails and recovery points.
Exactly my thoughts with the front and rear bumpers and winch.
I've been building a hunting specific rig out of my 96 xj for the last year and a half. Mostly my focus has been mods that will prevent me from becoming stranded somewhere remote, not necessarily for hardcore wheeling.
Front and rear bumpers with heavy duty unibody tie-ins
Rough Country Winch on the front
Dual batteries
Cowl intake (mostly to make room for 2nd battery but I get the "mini-snorkel" effect with it).
Gutter mounted platform style roof rack
2" lift
I also carry chains for all 4 wheels. I really don't want to get stuck in some of the places I hunt.
Got any more information on the cowl intake and dual batteries? I also have no desire to become stranded where I hunt. It would take a lot of walking to get out.
Chains are definitely on my list.
First order of business is make sure it has had the head replaced!
I was just reading about that yesterday. I plan on checking today after work to make sure I do not have the 0331 head. If I do, I will look into it. I drives very well.
Frame stiffeners get my vote, along with reinforcement for the steering box.
Check your motor and trans mount. Worn out motor mounts can put your fan into your radiator and that can leave you stranded out in the boondocks.
Get well acquainted with your crankshaft position sensor. Carry a spare and about 3' (yes, feet) of extensions so you can change it on the trail. Even better is to remove your current one and slot the holes so you can pull it out without having to fully remove the bolts. Then slot your spare as well.
I will check the mounts. Thanks! I'm very familiar with the CPS. I use to have a TJ on 35's years ago.
I received a boat load of paperwork with this thing on past maintenance. In the last 4 years it has received lots of new parts. I think they got tired of throwing money at it, when they got their last quote for repairs in Dec. It needs a new clockspring, a new driver side hood latch, and a blower motor resistor. The quote they got for those was almost 2k. I ordered the parts yesterday for less than 200. Should only take a few hours to have everything in excellent condition again.
They obviously did not know about the blower motor resistor, as they threw a new waterpump, heater core, thermostat, and radiator flush at it trying to fix the heat issue.
Let me know if yall can think of anything else.
Thanks!!!
