XJ Dana 30, High Pinion, Built $1200
live24wheel
Phoenix
Selling the 30 out of my XJ. Going to 1 tons. Specs on it are as follows...
1997 XJ Dana 30, High Pinion, Complete with steering, brakes, etc... NOT READY TO JUST BOLT IN! It is set up or 3 link suspension with a passenger side upper. The coil buckets are also centered in order to stretch the front 2 inches.
Yukon 4340 Chromos
Lock Right Locker
4.56 Yukon Gears
Ruff Stuff and Barnes 4wd Brackets
Solid Diff Cover
Ruff Stuff Steering, 1.5" 1/4 wall DOM with Ruff Stuff 3/4" Heims.
Welded Tubes
Spydertrax 1.5" Wheel Spacers
The story behind the axle. I did a FULL rebuild, all new bearings, everything when I did the gears, axles, etc. It has had less than 50 (fifty) miles put on it since break in, the gears, carrier and bearings are brand new as of last week. It has zero issues and I have 100% confidence in this axle within its obvious limits.
Contact me by text at 602-402-1326.
