XJ&CHZ4ME
- Unionville, MO
I have a Dana 44 out of an XJ and it is set up with new brakes (shoes, springs etc) and has 4.10's and is lincoln locked (welded). Right now it is set up to go under a YJ, but I will remove the spring perches if so desierd. You will need to relocate the perches to work back under a XJ. I have the perches to put back with it. I am asking $250 as it sits, or $300 if I put the new perches back on it and take the YJ mounts off. It looks like it could use a pinion seal, but that is just my opinion from seein it, it has been sitting on jack stands with the pinion pointed down for a while now. PM me if interested and with any decent offer. I need this thing gone before June 4th since I am moving. Could be persuaded to bring to Pig Gig if I can make it. Will help with delivery for fuel costs.
Located in 63565
Thanks-
Tyler
Located in 63565
Thanks-
Tyler
