loki_racer
- Pittsburgh, PA
does that crossmember use only the 3 tcase bolts? Stupid.
Yes and thanks for your insightful comment. You really added a lot to this conversation.
It is stupid. Sorry if the obvious offends you.
Very little reinforcement in that area. It's only designed to hold the transfer case not all the torque a front axle sees.
I haven't had a single issue with it. It works perfect for my DD. I'm just curious what you run?
Wow man, have you ever been under your jeep? Tranny x-member has two holes, the other hole has to be tapped. It is this way for EVERY long arm crossmember I have personally ever seen. But I guess maybe you would say TNT customs makes "stupid" products?
Go troll somewhere else.
Why bash companys cause you don't like there set up?
I guess if you didn't think of a easier way to do it, they suck right? OH well to each there own..
I'm new in here, My apologies, so maybe you aren't a troll. You came into the thread just hating on things, and then you mistakenly said 3 tcase bolts, and I thought "who is this guy coming in here just to start crap, he probably hasn't even got long arms" so I jumped.
Can you show us some case where not having it, and using just the three holes has proven to be an issue?
