Ironmanandy
- North Carlolina
Our mounting brackets are made out 3/16" 100,000psi steel. Mounts are 1/4" 100,000psi steel with a 1 piece Clevitee rubber bushing. Able to withstand the heat of the driver side exhaust and the deliver the torque to wheels with nothing wasted.
Perfect for offroad racing and extreme offroad use. Stock brackets and mounts even just for rock crawling are asking for trouble. Don't let weak stock mounts be the reason you put your fan through your radiator.
https://www.ironman4x4fab.com/xj-motor-mounts
Mounts & Brackets - $339.50
Brackets - $229.50
Mounts - $129.50
Brackets - $229.50
Mounts - $129.50
