WTT: 2 for 1 np231
JeepCherokeeGuy99
New Bern, NC
I have 2 np231J from 97+ xjs. One is stock and has a bent output shaft. The other has an HD SYE and tera low kit that is not working. Not sure what is wrong with it. Trade these two for 1 good working one from a 97+
Long time no see mike. If I have no takers on the pair then yes I will definitely consider it. I was hoping someone could make 1 nice unit out of both of these. If I had the tools and equipment I would take em apart and swap components.
i'll give you 50 bucks for the jacked up one, I have enough parts here to make one good one out of it :D
The 91+ is 23 spline. Somewhere around 94-95 the cut on the internal gears changed, but that's internal, and only matters if you're doing swaps of internal parts with teeth.
96+ had a sealed output as well.
I'll give you 100 bucks for the one with the bad tera low
Still need a working 231. Hit me up!
dumptruck is down in carlsbad and i'm 99% sure he wants to make this happen. he works 12 hour shifts most days at CTM and comes home dead to the world. I'll hit him up for you and see if he's still wanting to make the trade with ya. my place is right in the middle between you guys maybe we could BBQ and meet up :cheers:
Unfortunately his unit is a 242 :/ otherwise that would have been perfect!
Haha sounds good man. I need me a good tri tip sandwhich
