- Rainy side of Washington
So I have a bunch of stuff I am getting real tired of tripping over. I've posted it before but in separate threads and I'm just gonna collect it all into one spot.
21 spline AW4, free but you have to buy the np231 that comes with it for 50 bucks OBO. No tailcone iirc but if needed I can pick one up for an extra 10 bucks. I was gonna put this in my 96 but never ended up doing so, then I was gonna put it in my 91 and never ended up doing so, now I just want to stop tripping over it in my storage unit.
dark red (not sure of paintcode, non metallic) 96- header panel, free, has some chips, comes with assorted lights and wiring harness that may or may not make it work with a 97-up XJ
bright red nonmetallic 96- header panel and fenders, fenders have some scrapes on em, these will match a 94 perfectly and most other years of bright red very closely, comes with an assortment of lights, bezels, wiring harness I think, etc, 20 bucks obo
8.25 U-bolts, don't think they've ever been used, 20 bucks
99-up intake manifold, comes with an assortment of stock fuel injectors and a damaged fuel rail, 40 bucks, I will warn you that as far as I know (via JP mag) this won't result in a noticeable HP gain but if you think it will, I'll happily sell it to you so you can verify or disprove this yourself. I was going to put it on my 91 but I'm not going to be pulling the motor for a while, don't think I'll get a noticeable gain, and just want my money back.
dark red hood, year doesn't matter and I have no idea what it came off of, pretty sure it matches the header panel above, 10 bucks unless I already offered it to you free, friend of mine was gonna take it free but disappeared
97-up fuel tank, no pump assembly, has a single plug in it (done with epoxy, nitrile rubber, and stainless steel, I was careful to use only materials I know are fuel safe) where the junkyard had drilled a 1/4" hole in it to empty the gas out and I didn't notice till after I bought it. free. someone take this and make good use of it.
washer fluid spray / wiper arm cover bezel, dark red, not sure if it's late or early model or if it even makes a difference, free
at least one 96-up np231 in good shape, not abused, 75 obo, if these hang around any longer I will stuff them behind my fridge like mini-man did with the ones he's trying to sell
assorted parts off two 96 AW4s, free, all there except TV cables, one tailshaft, one pan, one set of solenoids, and one extension housing. both bellhousings, input shafts, pumps, the other set of solenoids, torque converters, whatever are up for grabs... verify parts are functional before using. If this junk hangs around much longer I will probably just give an almost whole transmission to whoever shows up first and tell them to deal with it. Otherwise it is being given to a scrapper. I want these gone or gutted for parts or perhaps shot and then buried in an unmarked grave, which would be fitting based on how much they ended up costing me in time, money, and annoyance.
there is much more stuff hanging around but most of it isn't annoying me / being tripped on enough for me to remember it.
