WTB ZJ rear axle
D44a or D35? Not that I have either one, but you never know what is different between the two. I have heard rumors that a TJ D44 will fit as long as you use aftermarket upper control arms.
Dana 35 is what it has now but either will work. Its just a stock 2wd ZJ that my brother just got for his GF and it has a bent rear axle. Already looked into using a TJ axle because we have a buddy that has one available but doing research it looks like you will need to cut a re-weld brackets for the shocks and spring perches to make it fit.
