Hi, hopefully I'm in the right section. I live in manassas va about an hour north of Richmond. I need an engine for a 2000 cherokee sport.
Thoughts, comments, suggestions?
Thanks
Zip code: 20112
After removing literally EVERY item necessary to pull the head itself, I discovered this.....
https://onedrive.live.com/?cid=9EF666F89D644D14&id=9EF666F89D644D14%213960&v=3
While I understand that this is a fine reason for missing, I think it is an exhaust valve and with the poshrod displaced, it should be closed.
What say the experts?...
In hindsight, I will try to remember to start with the valve cover next time.
Rick
You link the private version of your picture and we can not open it.![]()
