If I have a high pinion now with a 4.5 long arm lift with out cv front drive shaft will the low pinion still work. If so I'll take it.
Also wazzuxj how much will you want for the hp when your done with it
Ok sounds good I'll take that hp wazzuxj. Let me know when your done with it.
2stix my housing is bent and just plain worn out. Track bar bracket was welded to and then broken the previous owner just f-Ed up this jeep. I'm trying to rebuild it part by part.
