so if you ever have to mess with a t case on the trail, who are you going to pay then for a cheap rate?
its best to learns the ins and outs of your xj in the garage for the first time, so when it happens on the trail (or freeway) you already know the process . i am a firm believer that if you wont work on your junk in your own garage then you definetly wont be working on it on the trail. which means i or someone else has to work on your broken junk on the trail. which sucks for me or someone else. so learn to work on your junk. dont get me wrong, ill help you work on it either way of you rboke down on the trail....
plus the more you know your vehicle inside and out, the more you will understand its capabilities and where the strenghts and weaknesses exist.
its easy to pull a t case off. once its off, its easy to install a sye.
95$ is dirt cheap. ive heard rates as low as 450$ before to pull the case, install the sye, reinstall case.
that being said, i installed a sye on my spare t case the other night in like an hour or something after a bottle of wine. its pretty straigtht forward.
get good snap ring pliers otherwise you wont be movnig as fast on it
tcase removal:
pull driveshafts
unbolts shift linkage - its one 1/2" nut on driver side.
disconnect any vacuum lines, electrical, adn speedo stuff.
support tranny
unbolt 4 x-member to tranny mount bolts
unbolt 4 x-member to frame bolts
pull x-member
unbolt 2 18mm tranny mount bolts
unbolt 6 bolts (9/16) from tranny to t case
lots of u joints and extensions are a must for some of the ahrder to reach of the 6 bolts, and i also use ratcheing wrenches as well.
pull t case off. it only weighs 80 pounds.
install sye on case
reinstall t case on tranny
drink the rest of your 12 pack...
