Check the J.Y. or C.L. for a late 4 cyl. w/manual trans.
My early '96 is 4.10 w/ 27 spline, but they went 29 sp. sometime in '96, so count before you buy.
Mike
PM me an offer. I have a 8.25 4:10 with a spartan locker with less than 1000 miles on it. You will have to add the brake plates. i damaged one and removed them both because i was planning disk brake swap. You can pull them from another 8.25 or from a DANA 35 with minor modification by rounding out the hole a bit. I have since moved on to an 8.8 so i need to sell so i can fund my front axle upgrade.
