WTB AX-15
A TJ AX-15 with the flatter clocking fit in my '95 just fine, when the stock 231 was behind it. I ran into clearance issues when we swapped in a 241OR, that required energetic massaging the floor with a BFH.
Do note that I running the Novak cable shifter for the t-case, so I don't know if there would be an issue with the standard linkage.
David Bricker / SYR
