WTB ASAP: steering column and driver door
bigalpha
Moderator
Tucson, AZ
Need a tilt column with cruise control and a driver side door with power locks and windows.
Red door preferred but not mandatory.
Edit: I am thinking I maybe be able to repair the column.
I also need a set of rims and tires. I would definitely be partial to a set of ATs but looking for something decent.
Still looking for a column. Scored a door from Dave (need to figure out best way to get the money to you) but need a column. Found a guy with one for $200 but that seems steep as hell.
either one will be fine you should prefer a non tilt but they are interchangeable with eachother with no modification. don't limit your search to tilt only
I'm just limiting my search to a working, compatible column. I only found one in Tucson for $200. So if I can grab this one for $100 and get my hunkojunk working again, I'll take it
So the door was great but I can't rekey the 89 lock to fit a 91 key. So I'm still on the hunt for a door.
Dave, I haven't forgotten about you.
The hole for the cylinder is bigger and the chrome bezel is small on 90+ compared to 89-.. No worries though, I'm going to just JB Weld a 89- bezel to the front of the new 90+ cylinder and install it.
