Wtb a hp30 locker
Fyi a truetrac is a limited slip. Not a locker.
Good point. It depends on what you use your xj for. This worked great for me when I needed 4wd in the snow and still had decent handling, as well as increased traction when offroad. Some call it a more "aggressive" limited slip. If you are looking for 100% lockup all the time, this isn't exactly what you want.
Research it a bit and let me know. Make sure you know what you're getting and if it will meet your needs.
Good to hear. It's a great unit just want to make sure OP knew what it was.
For whatever reason some people seem to confuse the TrueTac as a locker.
Good luck to the both of you.
Josh
i ran 2 true tracs. i hated them . id rather be open or locked up front, the thing never gave me traction when I really needed it. the lockright up front makes all the difference in the world.
