GrimmJeeper
- Gardena, CA
I trimmed them back to within a 1/4 inch of the holes, then after I put the bolts in I bent the tabs inwards. The main rubbing points are at the front and rear of the fenderwells, not the top, if you omit the lowest bolt front and rear and put the bolts that go in from the bottom back in the flare should stay relatively close to the body and still be fastened well enough to stay on.
I have since removed the flare and folded the tabs all the way in though, I decided I like the look of not having them on better
