XJensen
- Sacramento
Good luck!
if you have compressed air & a 3 prong 220v 30 amp outlet then i can bring my plasma cutter & remove the LCA brackets fast.
i can bring air chisels & air hammers as well.
also can bring angle grinder etc.
need mini skids on the housing? i can fab them & weld them too.
let me know what you need, i have a pretty fair assortment of tools & equipment & other than my work i do not have a social life at all . :wow:
so do you need me to bring any of this or not?
anything to weld up on the front end before installation?
I would LOVE it if you brought this stuff but unfortunately I don't have 220 :-(
The only thing in the front that could use a weld is the Heavy Duty Track Bar Brace. The frame stiffeners will be installed another day.
Thanks for the offer!!!!!
so how did it go?
Josh
mark, what size drill bits do you need? any other special tools?
ask this question next sunday & you will get a much better answer... :twak:
j/k :conceited
i'll bring:
pop rivet gun & rivets,
7/16" & 13/16" drill bits & big drill gun,
L&R tin snips (for trimming fenders),
angle grinder with cut off wheels & grinding discs,
various other implements of destruction...
do you have an air compressor?
i can bring an air hammer & fold over the front inner wheelwell seam very nicely with it.
if not, we can do that at my shop when you get it running.
6:00 start? i don't want to twiddle my thumbs for 2 hours after work so
i think i will pass tonight & show up in the morning.
got a bunch of tools already loaded up ready to go.
got the drill bits needed.
let me know if you think of any other special tools i should bring.
what is the starting time tomorrow?
Im still down to cruz by tonight. You've got an air compressor right?
