Lawn Cher'
- Westampton, NJ
Is anyone interested in wrenching on my rig on Saturday? It is currently going through a major metamorphosis to 8" lift, 35" tires, 4.56 geared heavy duty axles, AA SYE, etc. I should have the chassis stiffeners welded in place by the weekend, so the following will still need to be done:
Clayton Longarm installation & front suspension dialed in
AA SYE & Tera 2-low installation
Leaf springs removed & replaced
D44 rear installation
front brake lines re-run to eliminate long flex lines
ABS system removal
A million small miscellaneous things (CB malfunctioning, roll cage padding, etc.)
I'm in no rush, but if we can get as much done as possible, I'll be in much better shape for all the events planned for the fall. I've been putting this off for far too long...
ABS system removal
