I picked up a 96 2-door, 126k from a friend for $1300. Didn't think too much about the floor being too bad since I had an 87 with not much floor board rust and twice the milage. Took up the carpet on the 96 and almost fell on the ground. Basically the all the bottoms of the floor pans need to be replaced except for the rear driver area (only a small hole there). Anyway, I would say it's definately worth the trouble of at least lifting up your carpet (wet sponge) and checking under there if you've never done it.
I was going to weld the new sheet metal in on the top side, then use body sealer for the underside before I POR-15 it, undercoat it, then herc the interrior. Does anybody have a good brand of sealer they recommend?
