hubs97xj
- Fort Wayne, IN
Got a good analog multimeter? Very easy to diagnose a faulty TPS with one.
Not so. Cam position sensor on a 99 is replaceable. ON earlier models (my experience with a 93) you had to take the distributor out and apart to replace it, but on later models (95 and up) it comes off the top. I did it on my 95. A five minute job.Unfortunately the cam sensor is inside the distributor and is not intended to be a serviceable part. Might check the wires and clean the connector with some CRC electronics cleaner from autozone (probably ought to do all of them judging by the pictures). Otherwise you might have to replace the distributor.
If you still have a P1391 after the new parts, you're gonna have to index the cam sensor in the dizzy.
DO THE FUEL FILTER!!!
Seriously, it seems like that was the original Wires and cap and such I'm SURE its the Original fuel filter and those things can make a HELL of a difference. Old Ford my grandpa had made the car not start even.
Its like a few bucks and maybe half an hour to change. If it were me, I'd do it first thing in the morning.
Defiantly blow through the old one to feel if its clogged. I would have got that in a heart beat.
3. The meter reading should be open (infinite resistance). Replace sensor if a low resistance is indicated.
it looks like the cmp sensor is reading 45 ohms
