Worn tires on front or rear?
jesterbomb
Alberta
What is the general concensus here, to put the two most worn tires on the front of the vehicle, or the rear? And when i say "the vehicle", I mean my 91 4wd XJ 5 speed 4.0L.
I'm asking because my buddy is letting me use any of the tires he has kicking around, to replace my worn out and scary Toyo's. I'm doing a lot of highway driving in the coming months and righ now it is three or four inches of slush, combined with freezing rain. But soon enough, it's going to be powder and ice.
So, which end should I put the better two on, the front or the rear?
Also, I made another post asking about wide versus narrow, feel free to comment on that thread as well. Just wanted to keep them seperate for future searchers.
http://www.naxja.org/forum/showthread.php?p=244638378#post244638378
Always put your best tires on the rear, even in a FWD.
I have always put the best in the front and never had any problems.
usually understeer is safer than oversteer, so put the better tires on the back.
And we have a winner!
If you lose traction in the front, the steering will enable you too attempt to regain control.
When the a**end of your vehicle is passing you, you are screwed.
I put my best tires on the front, and if they are so worn that it actually makes the vehicle unsafe then don't drive it.
I would rather be able to stop and steer then get moving fast, Good tires on the front
x2. that what i have always been told.
Huh? Blow out in the front on a soccer mom Explorer- crash and burn. Blow out in the rear, dang, gotta pull over.
I could see it either way, more traction for turning=good, but oversteer=bad. I guess it comes down to worn tires are usually chopped and cupped, which equals poor ride quality in the front, so the better ones go on the front. But the xj I'm driving at the moment has the better tires in the rear as the fronts aren't cupped.
Well, wasn't the explorer/firestone fiasco where the rear tire blew out and the driver panic, slammed on the brakes and caused the vehicle to spin (oversteer) which lead to vehicle flipping over...it was on the rear tires that Ford recommended the lower (less than 30psi) pressures...
SAme here, and mine's also got a Selec-Trac for that ugly white stuff:cool:
IIRC it was also more top heavy and had a "softer" suspension on top of all that.
None of the tires are cupped or in danger of blowing. It's just that two of the set are newer than the other three. So I would have the worst one as a spare, and I'm just trying to figure out where to put the ones with the most tread.
Seems like opinions are pretty strong on this issue. Compelling arguments on both sides though. I'm going to keep checking this thread, this is looking to be a motherlode of information.
Or at least entertaining.
