wont start have to hold the pedal to the floor?
MATTVW65
Layton Utah
I have a 91 XJ 4.0 ax15
I have to hold the pedal to the floor to get it started? Its acting like it is flooded. I have no enginge light on,took it to the local dealer "have a friend there" and he hooked it up and it told him that i was getting to much voltage to the map sensor and the coolent sensor...... ok i changed both without any improvement. I was thinking it was the TPS changed it ....nope. any ideas...
To much voltage to the map sensor and the coolent sensor or
To much voltage FROM the map sensor and the coolent sensor.
To much voltage to a sensor could be a computer problem, to must voltage to the TPS would cause hard starting.
make sure you are running stock plugs, I know it seems unlikely that that kind of problem would manifest itself when washing the jeep, but I have seen stranger.
also, listen to your ECU. I got the ECU in my 93 wet washing the engine once and had problems with the engine starting. The ECU was making a high pitched hiss/whine when the key was on. I disconnected and removed the ECU, cleaned and dried it thoroughly and the problems were cured.
good luck
