jerryrigxj
My xj I bought has a weird issue with not going past 2k rpms and when I try to push her past it she stutters and pops out the exhaust like she's going to die never stalls just her rpms go from 2k to 1k and pops I've replaced the throttle position sensors idle air control valve put a new fuel pump cause the old one was whirring so loud you could hear it in the car and people following me could hear it the new pump is now making the sound just slightly quieter have even put a new crank position sensor kinda out of ideas on what could be stressing the fuel pump out and causing the limit in rpms the 2k rpm limitation has persisted even after swapping out the noisy failing fuel pump
