WJ brake swap - what did you do to your ABS?
BlueGerbil
Germany
Guys,
I´ve sourced all the parts for a WJ brake swap - but now I have to think about the ABS system.
Please don´t let us discuss whether ABS is needed or not - if a vehicle comes ABS equipped from the factory than the ABS HAS to work to pass technical inspection in Germany to stay street legal.
My question - the stock XJ ABS sensors don´t work on the WJ knuckles. What have you done to make ABS work on an XJ with WJ brakes?
Thanks!
My bet is that the WJ sensors will work. They should pick up a signal strong enough for the XJ system, count the teeth on the XJ and WJ tone rings and see if it's different, also check diameter.
Good morning. I have a 2001 Cherokee XJ and I have modified the WJ knuckles and I need to keep the ABS sensors. How can this be solved? Thank you.
