Wiring HELP!
when is said guy available?;)
pm inbound to see if we can look at it this evening -- you da man, Joe!
just did...
Big thanks to Joe, I now have brake lights -- oddly, brake lights didn't work because of a bad hazard flasher... strange. Still struggling with the right turn signal -- the rear works only if the key is off, and there is power to its switch all the time when the key is on (even if the signal isn't). I appear to have a bad bulb socket in front right though, which may help a bit... Welcoming further opinions from anyone else, as the right turn signal issues left Joe and me scratching our heads this evening!
Thanks again, Joe :cheers:
I'm wondering if there isn't something shorting out inside the column to make the right side go live like that without a switch... I may pull the column further apart.
Who knows. I need to get a good look at a good diagram to get a beter feel for how it should be layed out. I will run it by a few coworkers and see if we can come up with a plan.
