Wiring Harness question
MVU2ORC
Temecula, CA
Hello all. Can anyone tell me what is supposed to plug into this piece of the wiring harness? I have had very little luck trying to find a good diagram that shows what every wiring harness connection is for. Rebuilt the motor and can’t find anything to plug back into it. Lesson learned to label everything better next time! 2001 XJ 2wd automatic no abs
I knew I forgot something!
rW58sAdF72H5iUc49
It looks looks your coil rail connector.
What are the wire(s) colors?
2 wires 1 Black with green stripe and 1 white
My 2k wiring diagram doesn't show those colors to anything that has 2 wires to it. But, because of the location my guess would "Evap Purge Solenoid".
:cheers::cheers:Finally Found a diagram that shows it. C113 MT. Manual Transmission connection. That explains why nothing is attached as I have an automatic😀
