Wireless Encryption program suggestions?
GSequoia said:
Win98 you can go to start - run - WINIPCFG, from there you'll be able to find the mac address (might have to tell it to give you more info..I forget, it's been awhile)
Should be OK, but it looks like it pulls the same nonsense with the dashes instead of colons:
You'll also need to change the drop-down from 'PPP Adapter' (which, IIRC, is the default) to the name of your wireless NIC in order to get the settings. Other than that, the instructions are exactly the same. Sorry about the odd highlighting of the IP address; this was the quickest example I could find.
