wiper help on a 1992 xj
yikes
SE Wisconsin
looking for the fuse/circut breaker/fusible link for the wiper motor circut. motor works through the switch if i jump a hot wire to the powre in going to the motor, but seems like there should be a fuse or something-who can help?---it is a 1992 xj.
dave
The circuit breaker is the big metal can one at the bottom of the fusebox. If you have intermittent wipers the module can go bad. You can bypass it by unplugging it and connecting the two connectors together. It is velcro'd under the driverside dash.
