I have a 2001 cherokee sport and the back driver side and the passenger window dont work the pervious owner spliced the 2 wires to the child lock already. Im not sure where to start next?
Apply 12 volts directly to the window motor to test function. Make sure the PO did the child lock bypass correctly. Faulty solder joints inside the front door switch assemblies are common. Inspect each wire harness inside the rubber boot at the hinges.
