Cherokeedad2
98 Cherokee 4.0 4 WD
The transmission started acting up a few months ago, classic symptoms, revs up and won't shift into First by itself
Searched for causes, started with the simplest solution. Disconnected the battery for a while, reconnected and codes went away, trans shifting normally
A month later, shifting issues again. Tried the next easiest step, cleaned the passenger side connectors and the ground on the dipstick mount. Trans shifted normally again.
Now, acting up again. Clearly, an electrical issue, so, what's my next steps?
