Will a Dana 60 rear from Jeep pickup fit XJ?
XJ Wagoneer 44s will bolt up, as it is the same as XJ Cherokee.
MJ 44s for XJ use need the old under axle spring pads zapped off and weld on new spring pads & shock mounts.
TJ 44s need same treatment as MJ 44s, Maybe easier to find locally? :dunno:
SJ (big) Wagoneer rear 44s are approx the correct width for an XJ, but same mods as MJ/TJ above, and are a different bolt pattern than the XJ/MJ/TJ
FYI, the carrier break for a Low Pinion D44 is 3.73 and lesser, 3.92 and greater.
