Will 96 seats fit in my 87 Laredo?
David Oates
I know seats have been discussed a lot, but I wasn't looking for this particular item in the past. I have a chance to purchase the front seats from a '96. Those in my '87 are bad -- head restraint broken etc. Will the '96 seats fit my '87?
The seat will fit but the mounting brackets will not fit. Your going to have to get the one from your 87, or fab up the one from the 96. But first check, because I have heard that 95' was the year that the seat brackets switch mounting locations. Juice
you should be able to unbolt the new brackets from the new seats and bolt your old ones right on.
the new seat brackets are extremely similar to MJ brackets, and I was able to do this swap
you end up unbolting the front of the seat bottom cushion and then you unbolt the back. that releases the whole seat frame from the bracket.
