5-90
- Hammerspace
Not to disparage Martin's maths (or his ability to run Excel, which is probably better than mine) but remember that the world is not a 100% efficient place, which is why I mentioned the error in calculations before. However, the 10% threshhold sounds reasonable, and you are still better off forking over for the transfusion than trying to dispose of all that fluid (that reminds me, I've still got 10 gallons of waste oil to get rid of...)
He is entirely correct on the running of the box to mix the fluid, and I'd add to that that you will want to sit there with your foot on the brake and run the transmission for at least ONE FULL MINUTE in EACH shifter gear range, so you can get the stuff that's in ALL the valve body passages involved. If you've ever overhauls an automatic transmission valve body, you know what I mean. If you haven't, just trust me on this...
Martin - which AW4 manual did you get? I've got the one from ATSG, which agrees with my 1989 FSM on the 8/4 quart fill levels. I'd like to find out more - and if you have a scanned copy, perhaps we could swap?
5-90
5-90
