I assume you mean a skid plate under the center section? A total waste of space, weight, and time. You don't need one, and it will only lessen your ground clearance so you get hung up more.
I ground the lip off the bottom as much as possible. I'm probably just gonna weld in a piece of 1/4" plate to the center section to make more of a ramp on the bottom. With the little bit of lip I have left I snag on little stumps and stuff.
