4x4JeePmaNthINg
- Colorado
I spent the last few days trying to find out what a noise was on my jeep. I pulled front shafts, swapped unit bearings, even replaced one that I had laying around, removed drive shafts. This sound remains and comes about at 30-50 mph.
The Jeep has 35" Mtrs and they have some cupping on one of the small treads. They all have this and I rotated them the last oil change, the sound didnt change. It sounds to be from the front of the vehicle.
Assuming what I am hearing is now due to this cupped tire issue. What would cause this now? Ive run many tires on this jeep, but Ive never had tire noise like this before, so I have no real experience on how to go about this noise issue.
My shocks are bilstein 5100, and when trying to rock the car and look for excessive bouncing, I see none.
Can these shocks still be bad even though the jeep isnt flopping around?
Should I test these shock in any other way?
Are bisltein 5100s up the task of running 35"s or is this a bit big of a tire for a shock designed for the XJ?
I appreciate any insight,
Thank you in advance.
