Which JKS discos to get?
Root Moose
ON, Canada
I'm putting a RE3.5" lift on my XJ.
Should I go with the JKS2000 (meant for 2-4" lift) or the JKS2001 (meant for 4"-6") of lift?
The RE3.5 gives more than 3.5" normally, right? Should the JKS2001 be used?
r@m
i have a OME 2.5" and a Dayster 1.5" boost so i should be at 4' lift hight and the JKS2001 i have is a tight fit at my hight if you are not going any higher go with the 2000. HTH
r@m
Go with the JKS2000 for that lift.
The fitment will be best!
mark
Thanks guys!
r@m
