If you have the lines hook up to the radiator then I know which ones are which. If you are talking at the transmission I am at a loss.
The line going into the upper connection on the radiator is the "hot" line. The line coming out the lower fitting of the trans cooling in the radiator is the "cold" line.
I installed the Mopar Aux cooler and they connect it to the bottom fitting on the radiator. The ATF flows through the aux cooler then into the rubber line crimped to the hard line connected to the transmission.
