Where to get U joints
SKIM
Newark CA
like the title said I cant find any where that sells the spicer u joints. I have heard to go with them not any other brand, or does it mater? it can be an online place.
thanks
For what?
For a front Axle I would say it matters, and go get the Spicer U's, but for the 1310 drive shaft I don't think it matters as much.
The 1310's are $20 with a lifetime warrenty at most all Napa/AutoZone/Kragen type of stores, and at $20 get a trail spair if it dose blow up on ya. You can always check with the local shops if they sell spicer U-joints.
I know Drive Line Specialties in Concord carries them, but that is a long ways away from you. I remember a place called Comet Automotive in Fremont or Union City does a lot of wholesale parts delivery to shops around that area. Call them and see if they can get some possibly on special order. The other place I can think of is The Parts House, although I have no idea if either is still in business. I used to work in Newark at the Goodyear off of Jarvis Ave by the Raley's about 10 years ago.
I have not cheack the parts house totaly for got about them, and yea they are still in business. I live like 3 min away from that goodyear i live near lincon school.
Thanks for the link, if I am reading it right they changed the U joint size some time in the 90's,my rig is a 94 does that mean I have the bigger 297/760 U joints:dunno:
I am pretty sure the change was in mid-year 96 that they went to the larger size u-joint.
My guess is that you have the 260 U-joint.
Can you go mesure it?
If you do have the bigger 297's get the 760 U-Joints for a little upgread.
Or go get a set of inner and outer Alloy USA axles to replace your stock axles, put a Full circle clip on that 760, or even spend lots and get CTM U-Joints in there! :confused1
Or go to a Pick-N-Pull and find some spair axles so when you do this you can replace them and get home:
47b4ce20b3127cce9bdec305d8cd00000025138IasWTVu5aE
thoes are the right ones - IF you actually have 260 joint shafts...
get out and measure your u-joint cap...
For 297/760 series U-joints, this measures 1-3/8" DIA. For the smaller / weaker 260 U-joints, this measures 1-1/8" DIA.
