robhurlburt
- lexington,ky
'95 XJ, 155K, 4.0l
Where does this go?
Do I have to fix this?
plugs into here:
Where does this go?
plugs into here:
The plastic line that is broken needs to be fixed. It is a vacuum line. The top picture could be a ground, but probably is a mounting attachment to keep the wire from falling down. Mine is also not attached. Someone on this forum will know what it is.
You could put a DMM on it to be sure, but I believe that's the plug for the underhood light.
another possibility for the underhood light would be to find an old XJ with the hood-mounted retractable light. I have one of these from an 87, though I keep putting off installing it on the 99.
For those unfamiliar with this one, it attaches to the framework of the hood itself, and the light nests in the bracket. It comes on with a mercury switch, and provides a little light as it stands, but it also pulls out with a cord several feet long, and has a magnetic base. Not very bright, but you can move it around and stick it to things. A clever design.
