Wheel Stud
Your local carquest/napa should have dorman hardware. Should be able to look up KJ studs. If you have the Chryco PN, they should be able to cross reference.
FYI - In case anyone is looking for the same. The knurled 3/8-24 x 1.5" "wheel studs" are the same as Polaris uses on many of their ATVs (grade8). I picked up 8 of these to use - perfect fit/length.
Just a confirmation post, Dorman PN: 610-449 does the trick for longer wheel studs in the rear with drums. I’m running Spidertrax spacers and only had about half thread engagement on the nuts provided due to the length of the OEM studs on the C8.25. A couple of hours and some elbow grease later with a breaker bar the new studs are on. More than enough thread for full engagement of the nuts on the spacer. Thanks again fellas.
