CyberHack
- Gauadalajara,Mexico
Hi i'm a complete newbie and i'm planning on buying a XJ 91-95 i also want to fit 33x12.50 on it, and i was thinking buying this lift kit the RE6111 that contain.
Adjustable front track bar.
T-Case Lowering Kit.
BRAKE LINE SS REAR.
SWAY BAR DISC SET W/ 6" CENT.
SWAY BAR DISCONNECT ADAPTER BRACKET XJ-ZJ
SPRING CLAMP CLIP 2.5".
COIL SPRINGS XJ 4.5"
BUMP STOP 2" FRT XJ/ZJ/TJ.
BLOCK & U-BOLT KIT 1.5".
5/16" CENTER PIN.
ADD-A-LEAF KIT XJ 2.5.
BRAKE LINES SS FT XJ
and i'm upgrading to Adjustable Control Arms upper and lowers.
also it comes with Doestch Tech 3K shocks.
All for 849 bucks. with this lift can i fit 33 with some trimming right ?
Or can i go with a 3.5 lift and add some spacers (2") ?
will i need something else to do it right the first time?
This will be a DD with some trails on weekends. some mud, little rocks, not hardcore trail.
thanks for your help.
BRAKE LINE SS REAR.
5/16" CENTER PIN.
