Lift finally installed, and got the tires mounted. Ended up having to cut pretty much every bolt out of the suspension. I still need to install the spacers up front, but they need to be modified, and I ran out of time.
Thanks! I went with the Rough Country 3" lift, with full springs, and a 1" shackle. I bought some 1" Pro Comp spacers, but they wouldn't fit over the bump stop mounts. Unfortunately, my other car broke down so I had to bolt the Jeep back together. I have the spacers opened up now, they'll go in as soon as I have a chance.
So busy day for me, i reinstall my electric fan to a proper switch and I also tore out my bench seat so that I can clean up the cab and redo the floorboards. next up is cleaning interior
Drivers side rear turn hasn't worked in a while and you get the "double click" sound when left blinker is on (front goes twice as fast). Just switched bulbs from one side to the other to test the bulb itself and it appears to be fine i.e. Both bulbs work on passenger side.
