What was done to YOUR rig(XJ/MJ) today MECHANICALY????
So I'm back. Took my battery to awful zone, they said it was bad and wouldn't take a charge, I said screw that and put it in the truck anyway. Fired right up.
So i also looked under the jeep and found out that my ba 10\5 lived up to it's reputation and blew its guts onto to highway so now I'm in the market for an early ax15
Swapped out my window.
Happy to have a good solid window in again. But of course, the Jeep giveths and takeths away. Fuse for my electric fans decided to burn itself up on the way home from ls1's.
Your fans do run a lot ;) Nice you got window replaced!
Ed you or someone mentioned the rear bump stops that are welded or bolt on with the rear leaf. You have a link or does anyone know what I'm referring to?
Eddy is just south of Waco... exit 315 on I 35. It comes with the brackets as part of the bumper? I do have JCR's frame stiffners unibody tie in and power steering brace but I will keep them.
I have to say a couple people are interested but you know how that goes. I will have to promise to first one with the money. Not an auction but first to pay... I seem to always have a lot of NOSHOWS :(
I have to... want to... replace Ball Joints :( does anyone have a ball joint removal tool I could borrow?
If not... suggestions... I bet mine have never been replaced in the 2000. I had the 87's replaced and they charged and arm and a leg so I want to do it myself. I will hopefully do coils at the same time :)
You can rent the press at Autozone. You'll also need the adapter set.
