What was done to YOUR rig(XJ/MJ) today MECHANICALY????
Re: What was done to YOUR rig today?
painted the ruffstuff diff covers for my 8.25 and d30 so when they get back from being regeared/locked they will be well protected!
replaced my broken e-broken mechanism
it sat in my driveway waiting for an alignment.
it will barely turn right and i can turn left forever. also the caster needs to be set
She's alive.. the 95 runs again.. got my fiance dirty putting the gas tank back in and she replaced the starter on her own.. next weekend is the locked up front axle hubs.. fun fun
wrench party at my place if your anywhere near Corpus
I understand...easy fix though...adjust the drag link.
I thought that you couldn't adjust the caster on XJ's (by conventional methods), but I could be wrong.
I purchased the critical path long arm kit from iron rock off road and its a 3-link kit... It has an adjuster for the caster.
[FONT=Arial, Helvetica][SIZE=-1]KIT INCLUDES: [/SIZE][/FONT]
  • [FONT=Arial, Helvetica][SIZE=-1]
  • 3 Piece High Clearance HD Subframe Assembly
  • Front Long Arms with 7.5° Caster Adjuster
  • 5.5" Coil Springs
  • 4.5" Leaf Springs
  • 1" Lift Shackle
  • Hydro 8000 Shocks
  • HD Track Bar with Double Shear Frame Mounting Bracket
  • Extended Length Stainless Steel Brake Hoses
  • Extended Length Front Sway Bar Links
  • U-Bolts
  • All necessary hardware
  • Detailed Installation Instructions[/SIZE][/FONT]
I realized that im spending more on my Heep than I had originally planned.
FINALY went through and hooked up my vacuum line corretly... I think.
Thanks for your help Jay.
Also changed the spark plug wires. Went and got some steel plate to finish my front bumper and for Jay to make axle side sway bar extender thingys.
