Replaced the water pump, again, on my Saturn. No more DuraJunk for me. Used an NOS GM water pump. Ebay was $20, dealer wanted $188, but said they were out of stock now, LOL. Found an NOS GM on Amazon for $88.
292,xxx miles on the Wagoneer and counting. :cheers:
I had to grind the shit out of and sand the outside roof on my Wagoneer last 3 months, pulled the luggage rack strips in the middle off, that had rusted holes under them in the roof, and ended up with about 30 holes in my roof by the time I got the deep rust pits out of the roof.
I used Rustoleum Rust Restore spray cans to prime and convert the remaining flash rust to primer, 3 coats, still need to go back this spring and finish sanding and grinding some locations, and I used a 30 year outdoor siliconized acrylic latex caulk, paint-able to seal the holes, for now. Then I had to pull the windshield top side trim as the head liner was still dropping a lot of water on the floor in the rains here, and found the same serious cancer rust (deep pits and all) hiding there as well. Ended up with a 20% hole area on the span of the tray. I used steel filled epoxy to seal and reinforce the large holes, one was 2" long by 1/4" wide. Used GE 30 year Silicone II, to seal the mini holes.
Caulked up the last leak locations in the passenger wing window.
Then still had some water getting in. Shinned a light from the inside up between the steel roof lip that supports the windshield and the windshield gasket and found a few paper thin gaps between the metal roof support for the windshield and the gasket, so I used a spray can of rubber like sealant/sealer on the entire tray/gasket area, after I had sprayed the cleaned up rusted tray with the Rustoleum Rust Restore rust converter primer. IIRC it has Tannic acid in it that converts the rust to primer. I have very high hopes for it. Used it on the hood about 3 months ago. But it must top coated as the primer is not UV/weather resistant. Still need to to put all the top coats on all of it.....Plan to use sandable grey primer (Rustoleum auto formula), then the OEM silver (Duplicolor), then a UV resistant outdoor clear coat (Rustoleum). The Rustoleum these days is easy to use in rattle cans, sprays sideways, up side down and the nozzle never clogs between uses. Awesome stuff if it holds up? I also bought a sealer primer for some of the areas. I plan to rattle can spray the entire rig and clean coat it the same way. Wish me luck!!!
