Had 12 volts to the O2 sensor, but the heater wire in the O2 sensor read 250,000 ohms, (should be about 8 ohms as I recall) as in it was dead. Swapped out the O2 sensor, and it went closed loop in seconds of start up.
But now had a rough idle??? WTF??? Still had fuel trims of 98(ST) and 128(LT).
Tried 3-4 restarts, about 8 cycles from run to off to run with out cranking, then suddenly she springs a fuel leak at the QC feed line to the fuel rail after tidying up the O2 and CPS and axle vent hose/wires with tie wraps to keep them from getting into axle shaft-steering column or exhaust manifold sudden death battles again. Must have bumped the QC too much and the 30 year old o'rings gave out finally. They were toast, inner one was rotted....
Replaced the 2 o'rings and spacer inside the 30 year old factory fuel line QC, stopped the fuel leak.
Oh, forgot to mention the fuel pressure was perfect before I changed the O2 sensor, I tested it first, FPR is working perfectly also before I swapped the O2 sensor. And O2 sensor ground was perfect.
Then the rough idle after replacing the O2 sensor, and multiple ign switch on off cycles and restarts stayed for 2-3 more restarts after fixing the fuel leak, and suddenly the jeep fixed itself.
I now have a self repairing jeep
:clap: LMAO.
Drove her today, several short trips, runs smooth as glass, even the sticky lifter has gone silent, she never ever ran this smooth before, at idle or under power.
What did I do wrong? LOL
Now we wait to see how well the slightly hotter NGK FR5 spark plugs on cylinders 1 and 2 stay clean (leaking valve stem seals from worn valve guides...long story) with a working O2 sensor?????? Fuel economy should go way up, I was down to about 11 mpg average so I already suspected an O2 sensor issue.
Now we tackle my dying hard drive on life line to the internet and Netflix
Hasta
Oh and I cleared out space in my shop for jeep parts, :clap: LOL. Got rid of three 20+ year old
behemoth massive main office copiers from the early 90s and one large window unit AC I never got around to fixing....and some other junk.
