Like the title suggests? I have to borrow/buy everything needed. :bawl: Only thing I know for sure is 1/2" socket for the pulley/flange bolts and 13mm for belt tensioner bolts. (`96 4.0)
15mm for belt tensioner
13mm or 1/2" for T-stat housing (I remove for room)
Small socket (8mm)? to remove E-fan & shroud---again room.
Screw driver or pliers to remove hose clamps
Scraper to remove gasket material
RTV and gaskets
Memory-----to remember where the different length bolts go....
