Don't do the coil compressors. You won't use them. Just jack the front end up by the "frame" and take off your tires. Jack one side of the axle up and if necessary push down on the other side. Remove coil, do what you gotta do and put it back together. I've used that method on stock coils with stock control arms, same with 3"spacers, RE 4.5" coils with stock control arms no spacers, 4.5s with 1.5" spacer and RE fixed LCA, and then most recently long arms and 5.5" coils. This time I tried the compressor, didn't work, so I went back to my old style.
At the very least, make sure they give you the external compressors if you do em. AZ just asks if it's coils or struts then give you the external compressors for the coil.
