Kejtar PostMaster General NAXJA Member Location Westminster, SoCal Jul 20, 2004 #1 I was just told that up on the AX15 on top there are couple bolts that take a reverse torx. Does anyone know what size ??
old_man NAXJA Forum User Location Loveland, Colorado Jul 20, 2004 #2 Surprisingly enough I have run across several XJ's that did not have those pesky torques, but had regular headed bolts. But back to the item at hand. What ever size you have, it isn't it.....Old Man's Axiom #13
X XJade NAXJA Forum User Location 87XJ_4L-Automatic, Arizona Jul 20, 2004 #3 Not sure if this is the info you need. YJ 4.0s can't be that different than XJ 4.0s right? http://www.bc4x4.com/faqs/yj.cfm?cat=5&faqid=139#faqtop
Jeff in VA <---respect Location Richmond, VA Jul 20, 2004 #4 E12, but check them first to make sure they're not hex. Jeff
