What size ram for Hydro Assist
jmop
Salem, Oregon
Ok, I want to get a hydro assist stetup on my XJ. I am trying to figure out what size of ram to run. It seems to me that if you run to large of a ram you will require quite a bit of fluid that will only be provided at a fixed rate. This will slow the steering wheel to the point that if the ram is too large you will not be able to perform fast menuvers on the street.
I am thinking about a 2" bore 1.25" rod. I don't know if that will work. Anyone have any suggestions.
I have a 1.5in 3/4in shaft ram, 8in stroke, stock pump. It slows down the steering a little. a 2in 1.25 shaft would be worse...
Here is my tech artical on how to doit and what rams to use:
http://www.wheelingarizona.com/tech/Hydro_info/DIY_HydraulicRamAssist.htm
thanks for posting I have read your threads a couple of times and I was wondering about that. If i have worked out the math correct the 2" bore would have about 175% more volume then the 1.5" bore. So if your steering was slowed down a little the 2" might be a little much.
With the front off the ground on jack stands, motor running, 1.5in ram mounted, If I try to turn very quickly there is a point where you feal resistance, if you turn harder you can go alittle faster.
At high speeds you never need to turn this fast, but when going fast like 35MPH on dirt roads you will feal the resistance, so you cant return to center as fast and cant turn as fast, so I slow down alittle on dirt roads now..
I rather slow down abit, then buy and install a new pump.
have fun.
